Hi all,
Is there a way to automatically space and arrange hole tags with a hole table in the same way that you can for dimensions?
See pic attached. I have about 50 panels to draw each with a huge number of holes in that production would like tagged for error checking. In this example I have manually positioned the tags after they have been generated but not sure I can stomach doing this every time.
Oli
I think the only control you have is the angle / distance in Document Properties;
In your particular example I'd probably find a way of increasing the drawing scale and/or reducing the font size to reduce the amount of rearranging. Alternatively, dimension the holes (with Ordinate dims most likely) and then the hole tags just become "A", "B", "C" etc. so it's less cramped than cramming in "A123", "A124" etc.
