Dear All,
can you help me to find a query that compare BOMs of two different assemblies in SolidWorks EPDM?
I would chose the Code of assemblies and the revision.
I would use this query in the Report Generator.
Thanks in advance.
Regards,
Ettore
Dear All,
Thanks in advance.
Regards,
Ettore
Hi Ulf Stockburger,
thank you for your reply.
I have this situation (for example):
Code assembly A; Revision 01
Code assemply B; Revision 05
each one of the two has a BOM associated for the specific revision.
I would to use the Report Generator for Compare the BOM of the first with the BOM of the Second.
Like the attached schema.
I'm not familiar whit SQL but I can try.
Thank's if you can help me.
Ciao
Hi Ettore
It is not exactly what you are looking for, but if you are familiar with SQL, you can start here.
PDM Professional - Named Bill of Material in SQL
BiI SAP-PDM
