My part is missing one of its internal faces. The face was created by cutting a hollow out of a larger solid, so I can't select the face itself in the tree or anything.
I've seen elsewhere that there is probably an error caused by my use of fillets, and probably freeform. However, the face is symmetrical to the opposite side, which shows fine.
I read about it here: Missing face on solid body
I'm having trouble finding my error though. Any ideas?
There seems to be something wrong with your sketch (sketch 2 of cut extrude 7 - the error exists after your second feature). If you replace the line that's making that face in the cut with a new line, it works. (turn the line into construction geometry, and then draw a new line over it). Of course making equation driven nested contours, but using the region anyway is a freakishly complex way of asking for problems. Is there a reason why you did it that way?
