I am trying to extrude cut some text but if I were to 3d print things like the center of an O will not be connected. Is there a font on Solidworks that connects extruded text to the part?
Google stencil font.
It sounds like you are looking for a stencil font. If your computer doesn't have one you can download it.
Depends if they're installed on your system. Here are some, but there are definitely more than this.
Curlz MT
Forte
Harrington
Magneto
Stencil
I have had no problems with Calibri also.
and you can use any font for sketch text and then „explode“ it. After that you are able to trimm it like any other sketch elements.
Or just extrude your own connectors wherever you want after the cut.
This thread has a laser cut font that I have been using.
Austine, could you able to solve the issue you had? If you solved could you share your update, please?
