AND10387 has standard drill size tolerances and I would like to create favorites based on it.
Solidworks 2019 Sp5
Hi Phil, under Hole specification, "?" mark sign on top right corner, click and the instruction given under segment Add or Update a favorite.
Did you follow this, if you does then I apologize. that's only thing I know. Please keep post your update.
Hi Hemantkumar,
thank you for replying.
I know how to save a favourite hole but it does not save the tolerances applied to that hole.
For example a hole saved as diameter .250 +/-.005 when recalled does not have the tolerance box filled out, it has to be done manually again.
Ok, I understood. Phil, thank you for the update. if you found out please let me know via post.
