I believe that there is a bug with the IAnnotation:SetLeaderAttachmentPointAtIndex method.
Here is a simple macro that just gets the existing arrow points and sets their position to their current position. Thus there should be no change to the note leaders. This works fine for one leader but seems to only move the first leader no mater what index you put in. Included is a test part and drawing with notes. Select a note and run the macro to test. Has anyone run into this?
Dim swAnnot As SldWorks.Annotation
Dim swNote As SldWorks.Note
Dim status As Boolean
Set swModel = swApp.ActiveDoc
Select Case swSelMgr.GetSelectedObjectType3(1, -1)
Case SwConst.swSelectType_e.swSelNOTES
Dim swDispData As SldWorks.DisplayData
Dim vArrowPts As Variant
Dim nLeaders As Integer
Dim i As Integer
'get the annotation
Set swNote = swSelMgr.GetSelectedObject6(1, -1)
Set swAnnot = swNote.GetAnnotation
nLeaders = swAnnot.GetLeaderCount
If swNote.IsAttached Then
'Save the arrow points information
Set swDispData = swAnnot.GetDisplayData
Dim vArrows() As Variant
ReDim vArrows(nLeaders - 1)
For i = 0 To UBound(vArrows)
vArrows(i) = swDispData.GetArrowHeadAtIndex(i)
Next i
're-position the arrows back to their original location
vArrowPts = vArrows(i)
Debug.Print ("leader " & CStr(i) & ": " & Format(vArrowPts(0), "####.####") & ", " & _
Format(vArrowPts(1), "####.####") & ", " & _
Format(vArrowPts(2), "####.####"))
status = swAnnot.SetLeaderAttachmentPointAtIndex(CLng(i), vArrowPts(0), vArrowPts(1), vArrowPts(2))
Debug.Print ("Status: " & CStr(status))
swModel.EditRebuild3
Next i
Case Else
'do nothing
End Select
Actually it is in an SPR so yep it's a bug. Several hours of debugging to figure out that I wasn't doing it wrong!
