Hi
I have a frame created as a weldment and I need to add some standard parts like fasteners to it. without creating a new assembly.
Hi
Save your assembly out as a part, and insert this into your part, or export assembly in dumb solid format (step) and re-import into SWX then insert into your part
vijay sarathy wrote:
Thanks. is this is the only way as I loose reference to original subassemblies
As Neville Williams said, the only way (as far as I know) to insert an Assembly into a Part is to save the Assembly as a Part first.
Hi. Drag fasteners from library.
When you see this window click Yes
