Hello everyone,
I was wondering if anyone has ever seen this before. If it is a known issue with Solidworks or if I did something crazy. I have been creating sketches for months now on a sheet metal flat pattern and making lines coincident with the auto-generated bend lines. The purpose of this is so the cutting machine just etches an inch long line instead of the entire length of the part.
So i started a sketch as usual, drew and dimensioned the lines as usual, and then when I exited the sketch, the lines just moved to seemingly random places. The size of this part was changed and extended from the original, but I have never had an issue with this before.
Anyone have any thoughts?
Not knowing the design intent, but:
1) Why make sketches on the flat pattern? It will be suppressed once flatten is cancelled.
2) Use relations (equal & symmetric) instead of repeating dimensions.
3) Your sketch doesn't appear to be fully defined.
Get out of flatten, add unfolds instead, add the sketch and then do the sketch bend.
Kevin
