I have Assembly designed with i.e. Part1, Part2, Part3 and
Part4.
Each part is separate sldprt file in folder.
If I remove Part3 from assembly and save, still Part3.sldprt is in folder.
How to remove unnecessary parts from disk?
This way is known to me, I search another, less inconvenient.
if it is in windows explorer you just need to delete it there (in windows explorer). i don't think that it you were ever able to delete a part from an assembly and have it completely delete the file from your computer.
WT
Design your parts 'top down', or otherwise known as 'in context' of the assembly, making them virtual parts, then if you delete them from the assembly, they will be gone! If you want to make them 'real' parts later, you can save them externally.
If you go with virtual parts, I suggest reading all you can on them, help files, forums, there's always pro/con to anything.
