Qin Bright
How to run a marco on the files in a particular folder.
Discussion created by Qin Bright on Apr 27, 2020
Latest reply on Apr 30, 2020 by Qin Bright
HI ,Below is  my code ,  I want to convert it to run on the files in a particular folder.
is there any tool can do it ,or Modify the code can do it?
Dim swApp As Object
Dim swModel As ModelDoc2
Dim vCustInfoNameArr2 As Variant
Dim cpm As CustomPropertyManager
Set swModel = swApp.ActiveDoc
Set cpm = swModel.Extension.CustomPropertyManager("")
Dim path As String, filename As String
path = swModel.GetPathName 'Get the Path name + File Name
filename = Mid$(path, InStrRev(path, "\") + 1) ' File Name With extension
filename = Left$(filename, InStrRev(filename, ".") - 1) ' Remove extension
a01 = Left(filename, 13)
a02 = Right(filename, Len(filename) - 14)
cpm.Add3 "PartNo", swCustomInfoText, a01, swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd ' write new value into custom properties
cpm.Add3 "Description", swCustomInfoText, a02, swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd ' write new value into custom properties
cpm.Add3 "Vrsion", swCustomInfoText, "1.0.0", swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd
