Hi all.
Is it possible to create either a circular or linear sketch pattern of this circle (A), with 9-degree spacing along with the dotted line where the current circle is?
So that means, there'll be 40 of the circles along the dotted line where the current circle on A is. Not sure whether I'm making any sense. I've been pulling my head to figure it out. I know I can just manually do a circular pattern on the 9 degree line like this but then to create the circle, I just don't want to do it manually. Taking way too much time.
Thought? Please advise?
i think you could achieve you goal much easier with using "vary sketch" option. Choose the angle dim as the reference for the pattern. Please noticed that i first created a body and second add a bore as the feature for the pattern. And i "melted" all splines together.
