I found this regarding my problem but couldn't find the SRP that Deepak Gupta mentioned.
This concerns a drawing of an assembly. When inserting a balloon it will display under "Balloon text:"-options a Custom Property named "Length" (which is a property of a Weldment part that is within the assembly).
This works fine until I want to change the balloon leader type to multi-jog leader.
CP's balloon sees before changing the balloon to multi-jog leader:
After the change to multi-jog leader:
I'm on SW2019 sp5 and I can't replicate your issue.
Whether I add the jog before or after changing the balloon to LENGTH, the balloons are fine and update with a change to LENGTH.
What SW version are you using?
Kevin
