Can you add date to a folder created via a macro?
Question asked by Dave Baxter on Apr 24, 2020
Latest reply on Apr 26, 2020 by Dave Baxter
Is there a way of adding a date to a folder created with a macro that exports a drawing to .dwg and .pdf?
This is the code I am currently using. It works fine with the tweaks but I could do with either the date after the folder name (not the drawing names) or a number to show the latest (continuation number). It is mainly so it does not overwrite older conversions.
Maybe:
'PDF_DWG_ClientRelease_24-04-20'  or 'PDF_DWG_ClientRelease_01'  or similar?
Code below... (I have removed some of the text for clarity)
' Updated to set sub folder as Output folder for PDF/DWG files. Change as needed.
Dim Filepath As String
Dim FileName As String
Dim boolstatus As Boolean
Dim longstatus As Long
Dim longwarnings As Long
Set swModel = swApp.ActiveDoc
s = Format(Date, "mm-dd-yy")
' Check to see if a drawing is loaded.
If (swModel Is Nothing) Or (swModel.GetType <> swDocDRAWING) Then
swApp.SendMsgToUser ("To be used for drawings only, Open a drawing first and then TRY!")
' If no model currently loaded, then exit
Exit Sub
Set swDraw = swModel
Filepath = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\"))
If Dir(Filepath & "PDF_DWG_ClientRelease", vbDirectory) = "" Then ' Change Sub folder Name here
MkDir Filepath + "PDF_DWG_ClientRelease\" ' Change Sub folder Name here
Filepath = Filepath + "PDF_DWG_ClientRelease\" ' Change Sub folder Name here
FileName = Mid(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\") + 1)
FileName = Left(FileName, Len(FileName) - 7)
swDraw.SaveAs (Filepath + FileName + ".PDF")
swDraw.SaveAs (Filepath + FileName + ".DWG")
MsgBox ("Files saved as DWG and PDF, see 'PDF_DWG_ClientRelease' folder" & vbCr & "Tweaked by DJB"), vbOKOnly, "by Deepak Gupta"
