CTChristopher Torres17/04/2020
I am currently working on an assembly that was initially made in china and I found this code that translates individual parts to English. I was hoping somebody could modify it to make it work on an assembly or give me some ideas on how I should proceed about translate all the parts inside the assembly and this assembly also has multiple sub-assemblies.
thank you.
by the way, I am currently using SolidWorks 2019.
Dim swFeat As SldWorks.Feature
Dim newName As String
Dim dicFeatsCount As Object
Dim collFeatsNonIncr As Collection
Dim dicBaseNames As Object
Const FrontPlane = "Front Plane"
Const TopPlane = "Top Plane"
Const RigthPlane = "Rigth Plane"
Const Origin = "Origin"
Dim isRefGeom As Boolean
Set dicFeatsCount = CreateObject("Scripting.Dictionary")
Set collFeatsNonIncr = New Collection
Set dicBaseNames = CreateObject("Scripting.Dictionary")
isRefGeom = False
'Add the list of features which shouldn't be incremented
collFeatsNonIncr.Add "SensorFolder"
collFeatsNonIncr.Add "DocsFolder"
collFeatsNonIncr.Add "DetailCabinet"
collFeatsNonIncr.Add "MaterialFolder"
collFeatsNonIncr.Add "OriginProfileFeature"
'Add the list of predefined base names
dicBaseNames.Add "MaterialFolder", "Material <not specified>"
dicBaseNames.Add "OriginProfileFeature", "Origin"
dicBaseNames.Add "ProfileFeature", "Sketch"
dicBaseNames.Add "Extrusion", "Extrude"
dicBaseNames.Add "RefPlane", "Plane"
Set swPart = swApp.ActiveDoc
Set swFeat = swPart.FirstFeature
While Not swFeat Is Nothing
If dicFeatsCount.exists(swFeat.GetTypeName2()) Then
dicFeatsCount.Item(swFeat.GetTypeName2()) = dicFeatsCount.Item(swFeat.GetTypeName2()) + 1
Else
dicFeatsCount.Add swFeat.GetTypeName2(), 1
If dicBaseNames.exists(swFeat.GetTypeName2()) Then
newName = dicBaseNames.Item(swFeat.GetTypeName2())
Else
newName = swFeat.GetTypeName2()
Dim i As Integer
Dim isIncremented As Boolean
isIncremented = True
For i = 1 To collFeatsNonIncr.Count
If collFeatsNonIncr(i) = swFeat.GetTypeName2() Then
isIncremented = False
Exit For
Next
If isIncremented Then
newName = newName & dicFeatsCount.Item(swFeat.GetTypeName2())
If swFeat.GetTypeName2 = "MaterialFolder" Then
isRefGeom = True
Dim sMatName As String
sMatName = swPart.GetMaterialPropertyName2("", "")
If sMatName <> "" Then
newName = sMatName
swFeat.Name = newName
Set swFeat = swFeat.GetNextFeature
If isRefGeom Then
swFeat.Name = FrontPlane
swFeat.Name = TopPlane
swFeat.Name = RigthPlane
swFeat.Name = Origin
isRefGeom = False
Wend
