Hello all,
Greetings!
Hope all are doing good and safe at this Covid-19 scnario. Wishing all good for all of us!
SolidWorks drawing exporting to PDF some sketch geometry is missing in PDF.
The invironment is: Part has some sketch geometry (No solid model, only geometry from skech lines) which has made for layout of base floor and the part has brought to assmbly level and then to the drawing is saved as PDF the PDF is missing the sketch geomtry from the part.
After investigation come to know, at assembly level part is checked with envelop option from Component Properties. So if we remove envelop option from component properties then it will be visible in the BIll of material(BOM) back in the drawing, adding more parts in the BOM table.
How we can get the correct PDF without disabling the envelop option in assembly.
Please let me know, If there is any work around for this issue.
Your language is difficult to read but from the sounds of it you need to enable enveloped component visibility in the drawing views. Open the properties of each view to see that tick box.
Also, you may have sketch visibility disabled in the drawing.
