Hi to all
I'm here to ask if someone know a way to rename the sheet in a drawing with multiple custom properties, for sample:
I have an assambly file where A is the code of assembly and A1, A2, A3... are the sub parts of its, I put the assembly file and all sub parts in the same drw file, sheet 1 assembly A, sheet 2 part A1, sheet 3 part A2 ..., now i want rename automaticaly the sheet with the follow custom proprety, code-revision-revision_date.
I found here a macro for rename with only one custom proprety, but I need with multiple custom proprerty
Rename SOLIDWORKS drawing sheets with custom properties values
Can someone helpme?
I've made a slight adjustment to that macro so it is easier to modify it as per your need. Please follow these steps
Dim prpName As String
prpName = InputBox("Please specify the custom property name to get the value from")
prpValue = GetCustomPropertyValue(swRefDoc, swRefConfName, prpName)
