Hey guys, I've been hunting about and haven't found anything simple for driving a model dimension from a drop down list of values.
My example is a driveshaft, and I want to drive 3 main dimensions from a drop down list of options that the CAD user can select from - i.e. stock material sizing, bearing sizing, etc.
I'm trying to avoid a design table as the client deems them flaky, but i can't see any other options, so i'm putting the question out in case I've missed something. note i don't want to create a ton of configurations (would be hundreds) only have the designer select from the options available.
appreciate the help guys,
Cheers
Duncan
if you can drive the part with equations driven by custom properties, you can put drop down lists in the property tab builder to drive the custom properties.
