Dimitrios Kokkinos
insert picture problem
Discussion created by Dimitrios Kokkinos on Apr 14, 2020
Latest reply on May 8, 2020 by Matt Shaffer
Hi
The below behavior happens in SWE SP02
When I insert or attach a picture in a symbol and try to edit the width and height to my desire values, the image seems to have a Lock Ratio between width and Height.
For Example, I need a picture 38mm Height x 28mm Width.
First of all, I insert the picture in the original size.
After with snaps points, I drag it to the desired size and from the right properties panel , geometry tab I define exactly the height and width.
If I choose again the picture the values have changed.
Also, SWE doesn't allow me to extend the image to X or Y axle using the snap points.
Yesterday morning I had inserted a picture in SWE 2019 SP5 , and works fine.
