Please tell me.
Please change this macrocode into the cord which is readable in SolidWorks2020
We would greatly appreciate your response.
Dim intDocType As Integer
Dim intVersion As Integer
Dim intOptions As Integer
Dim intErrors As Integer
Dim intWarnings As Integer
Dim blnRetval As Boolean
If ParentModelDoc2.GetType = swDocumentTypes_e.swDocASSEMBLY Then
Dim swConfMgr As SldWorks.ConfigurationManager = ParentModelDoc2.ConfigurationManager
Dim swConf As SldWorks.Configuration = swConfMgr.ActiveConfiguration
Dim swComp As SldWorks.Component2 = swConf.GetRootComponent
Dim CiledCompornents() As Object = swComp.GetChildren()
If CiledCompornents.Length > 0 Then
For i As Integer = 0 To CiledCompornents.GetUpperBound(0)
Dim CiledCompornent As SldWorks.Component2 = CiledCompornents(i)
Dim CiledFilePath As String = CiledCompornent.GetPathName
Dim CiledFileExtention As String = New FileInfo(CiledFilePath).Extension.ToLower.Replace(".", "")
Select Case CiledFileExtention
Case "sldprt" : intDocType = swDocumentTypes_e.swDocPART
Case "sldasm" : intDocType = swDocumentTypes_e.swDocASSEMBLY
Case "slddrw" : intDocType = swDocumentTypes_e.swDocDRAWING
End Select
intOptions = swOpenDocOptions_e.swOpenDocOptions_Silent Or swOpenDocOptions_e.swOpenDocOptions_AutoMissingConfig
intErrors = 0
intWarnings = 0
Dim swModelDoc2 As SldWorks.ModelDoc2 = swApp.OpenDoc6(CiledFilePath, intDocType, intOptions, "", intErrors, intWarnings)
If intWarnings = SwConst.swFileLoadWarning_e.swFileLoadWarning_AlreadyOpen Then
swModelDoc2 = swApp.ActivateDoc2(CiledFilePath, True, intErrors)
My.Application.DoEvents()
Call SaveComponentDiver(swModelDoc2)
swModelDoc2 = Nothing
CiledCompornent = Nothing
Next
CiledCompornents = Nothing
swComp = Nothing
swConf = Nothing
swConfMgr = Nothing
ParentModelDoc2.ForceRebuild3(True)
Dim FileName As String = ""
If ParentModelDoc2.GetPathName <> "" Then
FileName = New FileInfo(ParentModelDoc2.GetPathName).Name
Else
Select Case ParentModelDoc2.GetType
Case swDocumentTypes_e.swDocPART : FileName = ParentModelDoc2.GetTitle & ".sldprt"
Case swDocumentTypes_e.swDocASSEMBLY : FileName = ParentModelDoc2.GetTitle & ".sldasm"
Case swDocumentTypes_e.swDocDRAWING : FileName = ParentModelDoc2.GetTitle & ".slddrw"
End Select
Dim FilePath As String = TextBox1.Text.TrimEnd("\") & "\" & FileName
intVersion = swSaveAsVersion_e.swSaveAsCurrentVersion
intOptions = swSaveAsOptions_e.swSaveAsOptions_Silent
blnRetval = ParentModelDoc2.SaveAs4(FilePath, intVersion, intOptions, intErrors, intWarnings)
swApp.CloseDoc(ParentModelDoc2.GetTitle)
ParentModelDoc2 = Nothing
Looks some kind of mix of codes to me. Tried to compile with VBA editor and got following (commented rows not working) so you need to fix those lines ...
