Is there any recommended approach to analyze concrete screws. For example: Anchoring a plate with concrete screws and analyzing forces in that screw. Currently, I am using fixed constraint at the hole location, is it a realist approach when I cannot use bolt connectors or should I need to model the 3D screw.
Does preload apply to concrete screws too?
Please see attached.
There is no reason one cannot use bolt connectors here. It requires modeling of some portion of the concrete base.
Appropriate bolt pre-load will depend on the type of anchor being used, and how installation is specified.
I generally recommend moving boundary conditions at least one body away from areas of interest. This setup achieves that.
The added element count from the modeled concrete solid [I thought there was a generic concrete in the default materials library - here I used a common plastic instead] will add very little to the solve time. Solving the simultaneous contact and bolt tension problem will add significantly to the solve time - but that is the price for fidelity in this case, if the behavior near the joint is of interest.
