Dear All,
I have problem when create auto number wire after use Origin-Destination Arrow.
When I do not use Origin-Destination Arrow, I create auto the number wire, they are correct:
Page 1:
Page 2:
The numer wire in page 2 begin from: 0201. It is correct.
But when use the Origin- Destination Arrow, the number wire wrong:
Page 1:
Page 2:
The number wire in page 2 begin from: 0218.
I don't know why. Anybody to know how to fix this problem?
Thanks a lot!
The system for numbering the wires simply scans the page (top to bottom or left to right) and marks the FIRST instance of the wire it finds according to what it found in it's scan. Consider the scanning and page order and you'll begin to understand why wires mark earlier in the sequence. If you'd like to change the scan orientation, select as shown in the pic below. You may need to manually direct the wire layout, and can do so by right clicking on a wired area and selecting "edit connection path" to use a graphical indicator, or select "wire cabling order" to manually set the TO/FROM of the wire possibilities on an equipotential.
