Islam
Hi how are you
My little question is, hopefully everyone will solve.
I have a 1000ml bottle design.
How do I change this design to 500 ml?
That is, how can I determine the volume of a bottle?
I have to pour 500 ml of water.
thanks
Islam
Hi how are you
thanks
It depends on the shape of the bottle. Equations for volume of solids will be helpful. I recommend Google. Remember that you can't just scale the bottle because you also scale the bottle cap and neck and these are standard. If the bottle's geometry allows it, the easiest method is to use the "Move face" command (approx. 40-45%) by applying it to the bottom of the bottle. You can do it as a 1000 ml bottle configuration.
Hello, Muhammad. Could you share the file perhaps?
