Can't figure out how to add weird, compound angle view and dimensions. This tube has 2 bends, one of which is bent up and to the left a bit. Any tips or advice?? Thanks -
If you use a rotary tube bender you typically create a table. You start at one end and "walk along" the center line of the tube. You specify the length going from one bend to the other (measured in between the true tangent intersection points - virtual sharps), the bend radius, the rotation & bend angle. Or you use the x,y,z coordinates of the virtual sharps with the bend radius at any given point. The rest the machine software takes care of.
A good reference is "Tube forming processes" by Gregory Miller.
Also discussed in https://forum.solidworks.com/thread/231604
