Macro Find Notes on Drawing and Move Location
Question asked by James Dickson on Apr 9, 2020
I have this macro that will find the notes on drawing but getting an error because it's not checking the "Note" annotation filter box.
I thought the code below should check the box but not working.
"swUtilFindReplaceAnnotations.AnnotationFilter = gtFraNote"
Thanks for any help you can give.
Private Sub CommandButton_Move_Notes_Click()
Dim swApp As Object
Dim oData As New DataObject 'object to use the clipboard
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
If Update_Format.ComboBoxCurrentSheetSize.Value = "" Then
MsgBox "Select Currnt Sheet Size Before Performing Action"
Else
If Update_Format.ComboBoxCurrentSheetSize.Value = "DONE" Then
MsgBox "Select A New Currnt Sheet Size Before Performing Action"
Else
If Update_Format.ComboBoxCurrentSheetSize.Value = "D" Then
Set swUtil = swApp.GetAddInObject("Utilities.UtilitiesApp")
Set swUtilFindReplaceAnnotations = swUtil.FindReplaceAnnotations
' Redraw
Part.GraphicsRedraw2
longstatus = swUtilFindReplaceAnnotations.InitPMPage()
#If 0 Then
#End If
swUtilFindReplaceAnnotations.FindText = "NOTES:"
longstatus = swUtilFindReplaceAnnotations.FindNext()
#If 0 Then
#End If
longstatus = swUtilFindReplaceAnnotations.Close()
Part.EditCopy
Part.EditDelete
boolstatus = Part.Extension.SelectByID2("Sheet 1", "SHEET", 1.45053289166621E-02, 0.538618800586526, 0, False, 0, Nothing, 0)
Part.Paste
oData.SetText Text:=Empty 'Clear
oData.PutInClipboard 'take in the clipboard to empty it
