SOSean Orr08/04/2020
Hi there,
I am trying to run a conformal cooling simulation in SolidWorks plastics. I get as far as the solid mesh and then get this error " Transformation has failed. Please check the surface mesh". I checked the mesh summary, it says the mesh is waterproof there are no errors the aspect ratio is around 3 so i can't see what the issue is. If any of you know how to fix this it would be much appreciated
