I just stumbled into this.
I have a couple of config specific file properties - set using Property Tab. ("WIDTH" / "HEIGHT")
I have an unconfigured Global Variable "OFFSET"
Then a couple of equations that use these to calculate some model dims.
Works great until I added some derived configs.
Link to Parent doesn't work the way I expected, which is a bit rubbish, because it's very convenient.
It would be nice if the value actually was linked to the parent..
any ideas how to get this to work?
I don't work with derived configs much because the few times I thought they would be beneficial, they bombed and I had to back up the bus.
Anyway, I tried to replicate your post and, as for you, I get red when I go to the derived child config.
But I do get this message, so maybe this can lead you to some explanation.
Also, your OP states config specific WIDTH and HEIGHT but I don't see the @ in your image.
Sorry, not much help.
Kevin
