I have a tube welded to a solid end cap and have inserted a new part (the simulated weld) in to the weldment. my problem is that when I do a revolved cut to cut the OD down to the finish diameter the newly created "weld" does not "cut" along with the other components? I'm wondering if anyone else has experienced this/ solved this problem? I am running Solidworks 2020.
Brian
It sounds like this is an Assembly cut? If yes, edit the feature and add this Part under "Feature Scope."
