Hi all, I am working on a macro to inserting multiple parts into an assembly from a single folder location. It assumes the assembly is already open.
It loops through fine, however only the first part is coincident and fixed to the assembly origin. All other parts are not coincident to the origin, even visually. How would I correct this? I would prefer to do it after each part is added rather than all at the end. Code below, any help gratefully received!
Dim swAssem As SldWorks.AssemblyDoc
Dim boolstatus As Boolean
Dim sFileName As String
Dim Path As String
Dim nErrors As Long
Dim nWarnings As Long
On Error Resume Next
Set swAssem = swApp.ActiveDoc
Path = "E:\Scripting\"
sFileName = Dir(Path & "*.sldprt")
Do Until sFileName = ""
Set swModel = swApp.OpenDoc6(Path & sFileName, swDocPART, swOpenDocOptions_Silent, "", nErrors, nWarnings)
boolstatus = swAssem.AddComponent(Path & sFileName, 0, 0, 0)
swApp.CloseDoc Path & sFileName
Set swModel = Nothing
sFileName = Dir
Loop
Thanks, John
Credit: Deepak Gupta's code on this forum has already helped greatly, thank you sir.
