Miguel Gala
Insert Sketchtext on selected line
Discussion created by Miguel Gala on Apr 8, 2020
Hi everyone
I am trying to do a PMP, at the moment I have managed to go through an array that inserts the texts that I want, but I am not able to put them on the selected lines in the selectionbox.
this is the code:
Private Sub PropertyManagerPage2Handler9_OnClose(ByVal Reason As Long)
Dim i As Integer
Dim strNombrePlano As String
If Reason = swPropertyManagerPageClose_Okay Then
'numero de repeticiones del bucle, será el número de lineas seleccionadas
intNum_Lineas = swSelMgr.GetSelectedObjectCount2(2)
Set swSketchPlane = swSelMgr.GetSelectedObject6(1, 1)
strNombrePlano = swSketchPlane.GetNameForSelection(swSelDATUMPLANES)
Debug.Print "Plano de Croquis: " & strNombrePlano
'Create Sketch from the first selectionbox selected plane
swModel.Extension.SelectByID2 strNombrePlano, "PLANE", 0, 0, 0, False, 0, Nothing, 0
swSketchMgr.InsertSketch True
swModel.ClearSelection2 True
For i = 1 To intNum_Lineas
Set swSketchSeg = swSelMgr.GetSelectedObject6(i, 2)
' Select the line (this have to be de second selection box wich contains the lines for every text)
boolstatus = swModelDocExt.SelectByID2("Línea1@Croquis1", "EXTSKETCHSEGMENT", _
0, 0, 0, False, 1, Nothing, 0)
'Insert the text on the selected line
swModel.InsertSketchText 0, 0, 0, i, 1, 0, 0, 100, 100
Debug.Print swSelEXTSKETCHSEGS
Next i
Debug.Print "Total Lineas: " & intNum_Lineas
'Debug.Print strSketchLine_name
swModel.InsertSketch2 True
Any suggestion?
Thank you
