Select Named Entity of Assembly Component
Question asked by A. T. on Apr 7, 2020
Latest reply on Apr 8, 2020 by A. T.
Hello to everyone, I want to create a macro for automating the creation of an assembly document and the mating of two simple parts. So far I've managed to do the following:
1. Create an assembly document
2. Open the necessary parts
3. Import the parts to the assembly as components
At this point I want to select an already named edge of part No1 and an already named edge of part No2. I know I can use GetEntityByName and Select4 methods for selecting faces, edges and vertices inside a part document (example in code below), but I do not know how to apply the aforementioned methods for selecting a named entity of a component inside an assembly.
I would appreciate any help.
With regards,
Tasos
Option Explicit
Dim swEdge As SldWorks.Edge
Dim swEnt As SldWorks.Entity
Dim swSelectData As SldWorks.SelectData
Set swModel = swApp.ActiveDoc
Set swPart = swModel
Set swEdge = swPart.GetEntityByName("Edge1", swSelEDGES)
Set swEnt = swEdge
swEnt.Select4 True, swSelectData
