Why?
This is so bloody annoying!
I start typing in an email and look up and it's frigging filling in the password section of the PDM login window!
Stupid fool programmer!
Why?
From the Knowledge Base:
Solution Id: S-071660
Question
In the SOLIDWORKS® PDM software, how do I prevent a client from automatically logging in to a vault view or from displaying the login dialog when creating a new e-mail message in the Microsoft® Outlook 2016 (or later) software?
Answer
In the Microsoft® Outlook 2016 (or later versions such as 2019 and 365) software, the default action of the ‘Attach File’ button is to list files that were recently saved or worked with. This is a new feature in Outlook 2016.
If the list contains files from one or more of your local file vault views and you are not currently logged in to that view, a login prompt appears when you create a new message. Outlook triggers the login prompt when the list of items populate the attach file button and the folders in the view are scanned for the file name.
If you do not want to log in to the file vault view, you can cancel the login prompt and proceed to create the new message.
However, if you do not want Outlook to prompt for login, or to log you in to the view automatically if that setting is active, you can disable that behavior. For instructions, read the attached PDF document.
Question
Answer
