APAn Phan05/04/2020
Hi everyone,
Im having 2 problems with SW block insert right now:
1/ on youtube, when they inserting Autocad block into SW, the convert sketch board will show up, but when i try, SW just add the block in right away without the board, do they remove that step in the newer version or any other reason? When i open cad sketch that board still show up normally
2/ i already change the unit to MMGS but when i insert cad block in, they auto change to inch (like i have a 5mm square, when i insert to SW, it change to 127mm(5mm*25.4mm) square). i already save in both .dwg and .dxf and it still the same, how can i keep that 5mm square block after i insert it to SW?
Youtube video: https://www.youtube.com/watch?v=XN4clN7gvGY&feature=youtu.be, u can check at 0:50 when that board show up
My video for both problem:https://www.mediafire.com/file/yuqrvbuq0cgoy8t/block.mp4/file (sorry cause i dont know how to attach a video here, i press insert video and drag mine in, and then they play video, there is no button to add it in)
Tks in advance,
