Hello, as part of an internship projet, I've made a transient thermal analysis but I need help because it doesn't fit to reality.
The purpose is to heat an aluminium cell with 6 cartridges heater inserted inside the cell.
I've designed the cell, the heat insulator and the cartridges. I set the initial temperature for all the parts to 300K, the heat power to 40W to each cartridge.
(given by the cartridges datasheets) and the convection to all exposed faces to 10W/(m².K)(I've used the table for natural air convection and I've seen that the value is between 5-25).
I've also chosen the right material for each part.
To reach 200°C, in the software I need 80 second and, in reality, I need 10 minutes ...
What am I doing wrong?
If this is an internship, you should have a mentor, right? Do they have any opinion?
How are your 40W heaters controlled? I'm guessing you have the simulated heaters set to blast out straight up 40W into the aluminum. Unless you've done a superb job of matching things, your heaters probably can't run at 100% power during the entire warmup without overheating. Usually in the real world you have a temperature controller somewhere, that controls relays that allow current into the heater. Depending on the location of the temperature sensing device that's providing feedback to the controller, it may be limiting the heat output. Usually there's a light on the controller or on the relay that will tell you when the controller is allowing current to flow to the heaters. Are those lights on 100% of the time during heatup?
