Macro That Changes Sheet Format (Current Sheet Only)
Question asked by James Dickson on Apr 2, 2020
Latest reply on Nov 11, 2020 by Pattabi Kakumanu
I have a macro the updates our sheet format with new formatted templates. It works great except it changes every sheet with the new format. Is there a way to only change the current sheet I'm on?
Thanks for any help you can give?
If Update_Format.CheckBox_Change_Sheet_Format.Value = True Then
On Error Resume Next
If ComboBoxFormat.Value = "" Then
MsgBox "Select Sheet Format"
Else
Set SwModel = swApp.ActiveDoc
' Check to see if a drawing is loaded.
If SwModel Is Nothing Then
MsgBox "There is no active drawing document"
Exit Sub
If SwModel.GetType <> swDocDRAWING Then
MsgBox "Open a drawing first and then TRY again!"
Exit Sub
Set swDraw = SwModel
vSheetName = swDraw.GetSheetNames
' Traverse the drawing sheets and update the format
For i = 0 To UBound(vSheetName)
swDraw.ActivateSheet vSheetName(i)
Set swSheet = swDraw.GetCurrentSheet
vSheetProps = swSheet.GetProperties
'Set the sheet format to NONE
SwModel.SetupSheet5 swSheet.GetName, swDwgPapersUserDefined, swDwgTemplateNone, vSheetProps(2), vSheetProps(3), False, "", 0.4318, 0.2794, "Default", True
'Reload the sheet format from the speicifed location
SwModel.SetupSheet5 swSheet.GetName, swDwgPapersUserDefined, swDwgTemplateCustom, vSheetProps(2), vSheetProps(3), False, sTemplatepath & sTemplateName, 0.4318, 0.2794, "Default", True
swDraw.ViewZoomtofit2
Next i
swDraw.ActivateSheet vSheetName(0)
swDraw.ForceRebuild3 False
swDraw.Save3 1, nErrors, nWarnings
Set swDraw = Nothing
