Hi all gurus in solid works :-)
I have a BOM list where i wan to select some of the sub assys to show as a single item
Possible?
Possible?
I am used to Solid Edge, they are a bit better on this
The advantage with SW is that you can decide what to do for each configuration, and you can decide it on model, not just on the drawing. You might need to have 2 configurations, one showing all the children and the other showing the assembly as 'one part'.
Hi Arild,
you need to open the subassembly you want to show as single item and change the configuration properties.
RMB on the configuration
