I have a macro that will copy the notes from the format sheet and paste them on the front sheet. Everything works great except I cant figure out how to clear the copied notes from the clipboard. If I run the macro again and there are no notes on the format sheet it will paste the note from the last notes copied.
Is there a way to clear the copy clipboard or if there are no notes then do skip the paste.
Part of the code below. Thanks for any help you can give.
Private Sub CommandButton_Move_Notes_Click()
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
If Update_Format.ComboBoxCurrentSheetSize.Value = "" Then
MsgBox "Select Currnt Sheet Size Before Performing Action"
Else
If Update_Format.ComboBoxCurrentSheetSize.Value = "DONE" Then
MsgBox "Select A New Currnt Sheet Size Before Performing Action"
Else
If Update_Format.ComboBoxCurrentSheetSize.Value = "B" Then
boolstatus = Part.Extension.SelectByID2(" A", "SHEET", 0.104339414046694, 0.175981350443167, 0, False, 0, Nothing, 0)
Part.EditTemplate
Part.EditSketch
Part.ClearSelection2 True
boolstatus = Part.Extension.SelectByID2("Sheet Format1", "SHEET", 0.138783928127944, 8.60099041792129E-02, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SketchBoxSelect("0.138784", "0.086010", "0.000000", "0.009617", "0.262687", "0.000000")
Part.EditCopy
Part.EditDelete
boolstatus = Part.Extension.SelectByID2("Sheet Format1", "SHEET", 9.61700032325701E-03, 0.262686506578727, 0, False, 0, Nothing, 0)
Part.EditSheet
Part.EditSketch
boolstatus = Part.Extension.SelectByID2(" A", "SHEET", 1.11016776543454E-02, 0.261201829247639, 0, False, 0, Nothing, 0)
Part.Paste
https://stackoverflow.com/search?q=clear+clipboard+vba
"Application.CutCopyMode=False
on windows excel clears the dotted line and clipboard data is lost which is desirable."Also, "current" is misspelled in your msgbox commands.
