I've noticed that when I start SW via API methods or by using Activator.CreateInstance, many add-ins are not loaded. For instance, here is the Task Pane when I start SW normally (e.g. from its shortcut):
Note that the PDM add-in is loaded and the full list of available add-ins is extensive:
When I start it from code, the PDM add-in is not loaded
and the list of available add-ins is much shorter
Is there any way to ensure that SW starts in the same way from code as it does when starting it normally? I see that there is SPR 453529 (Starting SolidWorks from third-party application and bringing it to foreground does not load the active add-ins), but no workaround is provided.
Check the second part of this article: Create C# stand-alone application for SOLIDWORKS API automation
