Weld call out displays but no visual "weld bead", this occurs in part and assembly. Did they delete that?
Are you using Fillet Bead, or are you really using Weld Bead?
This had to be added in earlier releases.
I finally found a right click option somewhere and it turned it back on. Tried to delete the post but did not have much luck. Got several welded products in the que and will have to look into this again. Thank you very much for helping out.
