I'm trying to extend the macro
to work with 3D Sketches. I managed to make a version that gets points in a 3D Sketch and lists their coordinates. But I can't figure out how to fix them. The macro fixes the 2D Sketch points in the attached .sldprt file, but not the 3D Sketch points. Some files have many 3D Sketches, so manually editing sketches is impractical.
If FeatType = "3DProfileFeature" Then
Set swSketch = Feature.GetSpecificFeature2
longSketchStatus = swSketch.GetConstrainedStatus()
If longSketchStatus = 2 Then
Part.ClearSelection2 True
boolstatus = Part.Extension.SelectByID2(FeatName, "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
Part.EditSketch
boolstatus = Part.Extension.SelectByID2("Point1@Origin", "EXTSKETCHPOINT", 0, 0, 0, True, 6, Nothing, 0)
longstatus = Part.SketchManager.FullyDefineSketch(1, 1, 1023, 1, 1, Nothing, -1, Nothing, 1, -1)
'Execerpted from https://help.solidworks.com/2018/english/api/sldworksapi/Get_Sketch_Points_Example_VB.htm
sketchPointArray = swSketch.GetSketchPoints2
For ii = 0 To UBound(sketchPointArray)
Set swSketchPoint = sketchPointArray(i)
' Get the x & y coordinates
Part.SketchAddConstraints "sgFIXED"
xValue = sketchPointArray(ii).X
yValue = sketchPointArray(ii).Y
Debug.Print "Sketch point coordinates: "
Debug.Print " x: " & xValue
Debug.Print " y: " & yValue
Debug.Print " "
Next ii
Part.SketchManager.InsertSketch True
sketchaddconstraints adds constraints to the selected entities. You have to select the things you want to fix before you try to fix them.
