Change OD ???
Discussion created by Guest on Jun 17, 2006
If you look under where you pointed the arrow, you will see a box that say Fix Diamter. Check this and it will make the harness fixed to whatever diameter you use.
But you should really create a library file with your wire sizes and cable sizes.
