I just bought the Solidwork Student edition and at the end of the set up when i click install i get a window that says
"Specify the port number and server name for the SNL server . The default is . For example , "25734@myserver". Separate entries for multiple servers with semicolons.
Port@server : 25734@localhost
If the port number and server location are not specified solidworks products may fail to run ."
Im Installing this in my pc . I dont know what port should i use and if i cancel i get this msg
"Do you want to continue without a valid SNL server. "
This means that the serial number you used is a network number and not a single computer standalone number. Can you let me know where you got this Serial Number from?
