hello,
I have been tasked with converting all of our inventor drawings into solidworks drawings this is a problem because my company uses decimal points to determine tolerances, right now in a drawing when I have a degree that is exactly 45 or 90 or whatever it is, it wont display a point zero,or zero,zero. I have tried turning up the tolerance/precision but that doesn't do anything. I need those extra decimal places to appear if its possible.
in DRW : Document Properties / Dimensions / Trailing Zero = Remove
but to change this setting for futur/new DRW, you have to do the change to the DOTDRW file.
(and also update the "drafting standard" file SLDSTD if you manage it).
