I've read the help section about Inventor files as well as several previous threads regarding the topic. I have Solidworks 2019 SP3 and Inventor View 2020 installed. We receive Inventor files on occasion, but not enough to warrant a seat. Anyone have success importing? If so, what was your workflow? I've tried with and without 3D interconnect and with Inventor View running (but nothing open in it). No matter what I do I get an empty file, but no errors. I don't know what version the Inventor files were saved in last.
Aaron,
Do you have the entire project from Inventor? We often do this, and as long as you have viewer installed (you may want to try the same release years - for example we use SW2018 with viewer 2018) then simply do a file / open / change file type to .iam then open - (make sure it is a project - folder has .ipj). Using the 3dconnect will allow you to grab all of the metadata.
