RWRene Wolters24/03/2020
I working an a macro to extract configurations from a aesigntable Part. Compareable to the famous ConfigRipper.
Unfortunately I'm not a programmer on daily basis but found enough ideas for getting so far and now
the only thing missing is:
I'm not able to copy the configuration specific properties to the custom properties and after that delete all configuration specific properties.
here is the code of my subroutine:
Sub RemoveConfigurations(filePath As String, confToKeep As String)
try:
    On Error GoTo catch
    Debug.Print filePath
    Debug.Print confToKeep
    Dim boolstatus As Boolean
    Dim cusPropMgr As SldWorks.CustomPropertyManager
    Dim nNbrProps As Long
    Dim value As Integer
    Dim vPropNames As Variant
    Dim vPropTypes As Variant
    Dim vPropValues As Variant
    Dim resolved As Variant
Dim lRetVal As Long
Dim lRetVal2 As Long
Dim lRetVal3 As Long
Dim lRetVal4 As Long
Dim lRetVal5 As Long
Dim config As SldWorks.Configuration
Dim ResolvedValOut As String
Dim wasResolved As Boolean
Dim swDocSpec As SldWorks.DocumentSpecification
Set swDocSpec = swApp.GetOpenDocSpec(filePath)
swApp.DocumentVisible False, swDocumentTypes_e.swDocPART
Set swModel = swApp.OpenDoc7(swDocSpec)
swApp.DocumentVisible True, swDocumentTypes_e.swDocPART
Set cusPropMgr = swModel.Extension.CustomPropertyManager(Empty) 'config.CustomPropertyManager
swModel.ShowConfiguration2 confsToKeep
    Dim vConfNames As Variant
    vConfNames = swModel.GetConfigurationNames
    Dim i As Integer
    Set config = swModel.GetActiveConfiguration
    Set cusPropMgr = config.CustomPropertyManager
    For i = 0 To UBound(vConfNames)
              Dim confName As String
        confName = CStr(vConfNames(i))
        Part.ShowConfiguration2 confName
        If Not confToKeep = confName Then
            swModel.DeleteConfiguration2 confName
            Debug.Print confName
        Else
             ' Get the number of custom properties for this configuration
            nNbrProps = cusPropMgr.Count
            ' Get the names of the custom properties
            'lRetVal =   'cusPropMgr.GetAll vPropNames, vPropTypes, vPropValues
            'get property names
            For k = 0 To UBound(vConfNames)
               Set cusPropMgr = swModel.Extension.CustomPropertyManager(vConfNames(i))
'Comment : here the counting of the config propertiers goes wrong, I hav 22 Properties, but Ubound is over 38
' and the the process runs into an error
               If Not IsEmpty(vPropNames) Then
                    For j = 0 To UBound(vPropNames) 'Delete all custom properties for each configuration.
                        Debug.Print sConfigName & vPropNames(j) & vPropValues(j)
                       lRetVal2 = cusPropMgr.Delete2(vPropNames(j))
                    Next j
            Next
Next
Set cusPropMgr = Nothing 'Clean
     bRebuild = Part.ForceRebuild3(False)
    'If False <> swModel.Extension.HasDesignTable() Then
        swModel.DeleteDesignTable ' delete design table in saved part
   ' renaming the config
    boolstatus = swModel.EditConfiguration3(confToKeep, "Standard", "", confToKeep, 32)
    swModel.Save
There are 22 config specific properties, but Ubound always states there are 38 and the deleteing process runs into an error. It somehow seems that the properties are counted twice
Can someone give me a hint, what I did wrong here?
Regards
René
