I had this problem in SW 2019 and with other people's help here I was able to get past it. Now I am working in SW 2020 and the problem has reared it's ugly head. When I create a new view (whether it be an Auxiliary, Detail, Section, Orthographic or other) I get the view scale in the label below the ID. How do I make it go away. It's annoying and frustrating all at the same time. I have changed the setting in Doc Properties for all views to have a scale of NONE (see below), But I still get the scale.
Please Help!!!
There isn't technically enough info in this post to fully know what's going on in your case. However, you are using ANSI, I'm guessing. As such, using the view scale that is different from the sheet scale requires a notification of the view scale. If you wish to deviate from the standard, you can modify these settings in the template you are using and save it to a new drawing template. Then, when you use your template, those settings should carry over to any new drawings. If you are modifying existing drawings where you haven't yet changed those settings, you'll have to change these settings for those drawings. To copy the settings from one drawing to another, you can use Drafting Standard functionality on the top page of the Drafting Standard in the Document Properties.
