Hi.
Trying to make a extrude cut in a sheet metal door, but it seems i can not do that.......
Why??
I got som edge-Flange yellow error
But i have been told it is no problem that it is like this, and the size of the door is controlled by equations.
I have saved the door as a part and added it.
Any help is really appriciated
I have this same problem occasionally, but mine seems to be on files where there is an imported part as the base feature.
I have managed to work around this problem by cutting/revolving/swept cutting/lofted cutting from different surfaces or planes. I also have some instances where this does not work and I cannot get my cut features to work at all.
Ole Sundheim in your case, it looks like you're trying to cut a rectangular hole through the main sheetmetal face, correct? You may add a plane (if we are looking at the front plane/front view) offset from the right plane to the starting point of your rectangle and cut extrude left to right (or opposite) in the image view you showed to achieve the end result and possibly work around the failed cut feature.
If anyone else has a solution/better work around for this problem I would still like to know as I have a few that I was never able to get to to work from any direction or feature operation.
