I can't seem to find any documentation on GetExternalFeatureReferences2 members. In visual studio I seem to jet get that it is a com object. Working from this documentation there looks like there are at least four members:
ExternalReferences
ReferencedConfigurations
BrokenStatus
IDs
In that example there is a line that says:
Debug.Print(" Broken reference (1=broken; 2=not broken; 0=older version or N/A): " + brokenStatus[i]);
Are these all the values that are returned?
I also find the Enum swExternalReferenceStatus_e in the SolidWorks API. IT has different values and does not have a "2" for some reason.
I hate guessing on these kinds of things. I am using this to write tests of files that can be automated before release to manufacturing.
Hi Eric,
The methods involved are documented in the API help. Start here and review the Remarks section.
2020 SOLIDWORKS API Help - GetExternalFeatureReferences2 Method (ISwDMDocument18)
If that doesn't get you what you need, could you add a little more detail to your question?
FYI, the BrokenStatus property uses the swDmReferenceStatus_e enum, not swExternalReferenceStatus_e.
Mike
