Hello everyone.
Following the Help:
Tools > Equations, Equation View,
In the Global Variable section, i can see grey 'Add global variable' which disappears when I type:
Drod
Pressing Tab key:
It becomes "Drod" and sign = appears in the Value/Equations column
Typing: 1.5
Units: mm from the drop-down sub-menu
Green appears in the cell, indicating that the syntax is valid.
But the global variable value does not appear in the Evaluates to cell. The cell remains grey and non-editable and the cursor does not move to the next cell in the Comments column. The Comments is white, but non-editable.
IF TO PRESS OK: 'There is a syntax error in the active Equation. Do you want to exit the dialog box?
IF TO PRESS Yes: The box disappears but when re-opening it, the Global Variable section is empty.
IF TO PRESS "Rebild" icon: Global Variable section becomes empty.
Also in the sketch, Dimension > DoubleClick > Modify dialog box, I cannot obtain the Global Variable icon (blue globe with yellow star), which I managed to obtain once in the past with this software.
Maybe the Global Variable functionality is somehow turned-off in this software?
Maybe the software is damaged by Users?
Any idea how to recover it, please?
Thank you.
(A beginner in SolidWorks)
- used to refer to a person or thing that is different or distinct from one already mentioned or known about.The idea had been put forward that she was making it all up, that she had a fantasy or some other motive.
- further; additional.reporting three stories and rewriting three others
- that which is distinct from, different from, or opposite to something or oneself.Thus it is in opposition to the other that psychoanalysis has conceptualised the self to emerge.
- view or treat (a person or group of people) as intrinsically different from and alien to oneself.a critique of the ways in which the elderly are othered by society
I tried to find a way around:
I make a linked dimension in a sketch of one of the parts in this assembly:
RightClick on the Dimension > Link Values > assigned the name D2 for the Dimension > OK > red infinity symbol appears next to the Dimension.
Now going to another sketch in the same Part:
DoubleClick on the Dimension > Modify > in the value cell, type = > [sub-menu] > Global Variables > [D2 in the list] > selecting the D2 name > ="D2" appears in the value cell, Green
appears in the cell, but if I click on it, the Modify box does not close: still it does not work.
Please advise what to do.
Thank you.
