Hi all,
I have an assembly including a couple of components (part/assembly). When I try to delete one of the components from the assembly, Solidworks just crashes every time I did it. However, when I suppress the same component, it doesn't crash. I have used this model many times before and it never happened. I have tried to restart the computer and run Solidworks on its own, but the problem still exists.
Can anyone instruct what should I do to fix the problem please?
Thanks in advance.
1. Attach the assembly with all parts (pack&go).
2. List your version & SP.
3. Can you replace the offending part w/o issue?
4. Have you tried saving the assembly & modifying that copy instead of the original? Did you get the same results.
