ISMAEL DIAKITE
Hello, I created two macro, the second depends on the first because I do an extrusion with removal of material and I have to select the face on which I have to extrude. can i perform these two actions in one and create a macro? I put the two macro. Thank
Discussion created by ISMAEL DIAKITE on Mar 13, 2020
Latest reply on Mar 17, 2020 by ISMAEL DIAKITE
Macro 1
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
Part.ClearSelection2 True
Dim skSegment As Object
Set skSegment = Part.SketchManager.CreateCenterLine(0#, 0#, 0#, 0.090055, 0#, 0#)
Set skSegment = Part.SketchManager.CreateLine(0#, 0#, 0#, 0#, 0.032106, 0#)
Set skSegment = Part.SketchManager.CreateLine(0.05382, 0.032106, 0#, 0.05382, 0.048891, 0#)
Set skSegment = Part.SketchManager.CreateLine(0.05382, 0.048891, 0#, 0.076734, 0.048891, 0#)
Set skSegment = Part.SketchManager.CreateLine(0.076734, 0.048891, 0#, 0.076734, 0#, 0#)
Part.SetPickMode
boolstatus = Part.Extension.SelectByID2("Point4", "SKETCHPOINT", 0, 0.03210551301655, 0, False, 0, Nothing, 0)
Set skSegment = Part.SketchManager.CreateLine(0.05382, 0.032106, 0#, 0#, 0.032106, 0#)
boolstatus = Part.Extension.SelectByID2("Line2", "SKETCHSEGMENT", -2.6643579266844E-04, 0.020648773931806, 0, False, 0, Nothing, 0)
Dim myDisplayDim As Object
Set myDisplayDim = Part.AddDimension2(-5.67508238383831E-02, 1.85172875904583E-02, 0)
Dim myDimension As Object
Set myDimension = Part.Parameter("D1@Sketch3")
myDimension.SystemValue = 0.02
boolstatus = Part.Extension.SelectByID2("Line5", "SKETCHSEGMENT", 4.78008298755187E-02, 0.013195020746888, 0, False, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(8.59751037344398E-02, 1.45228215767635E-02, 0)
boolstatus = Part.Extension.SelectByID2("D1@Sketch3@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D2@Sketch3")
myDimension.SystemValue = 0.034
boolstatus = Part.Extension.SelectByID2("Line4", "SKETCHSEGMENT", 4.24896265560166E-02, 3.44398340248963E-02, 0, False, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(4.23236514522822E-02, 5.30290456431535E-02, 0)
boolstatus = Part.Extension.SelectByID2("D2@Sketch3@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D3@Sketch3")
myDimension.SystemValue = 0.012
boolstatus = Part.Extension.SelectByID2("Line5", "SKETCHSEGMENT", 4.74688796680498E-02, 9.70954356846473E-03, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Line2", "SKETCHSEGMENT", -3.31950207468873E-04, 8.38174273858922E-03, 0, True, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(6.63900414937774E-04, 5.02074688796681E-02, 0)
boolstatus = Part.Extension.SelectByID2("D3@Sketch3@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D4@Sketch3")
myDimension.SystemValue = 0.06
boolstatus = Part.Extension.SelectByID2("Line1", "SKETCHSEGMENT", 0, 0, 0, True, 0, Nothing, 0)
' Named View
Part.ShowNamedView2 "*Trimetric", 8
Part.ViewZoomtofit2
boolstatus = Part.Extension.SelectByID2("Line1", "SKETCHSEGMENT", 0, 0, 0, False, 16, Nothing, 0)
Dim myFeature As Object
Set myFeature = Part.FeatureManager.FeatureRevolve2(True, True, False, False, False, False, 0, 0, 6.2831853071796, 0, False, False, 0.01, 0.01, 0, 0, 0, True, True, True)
Part.SelectionManager.EnableContourSelection = False
Macro 2
Dim swApp As Object
Dim Part As Object
Part.SketchManager.InsertSketch True
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swSketchAddConstToRectEntity, swUserPreferenceOption_e.swDetailingNoOptionSpecified, True)
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swSketchAddConstLineDiagonalType, swUserPreferenceOption_e.swDetailingNoOptionSpecified, True)
Dim vSkLines As Variant
vSkLines = Part.SketchManager.CreateCenterRectangle(-4.28908012694641E-03, -3.56646336642825E-02, 0, 5.59445233949533E-03, -0.025501378580866, 0)
Part.SetPickMode
boolstatus = Part.Extension.SelectByID2("Line3", "SKETCHSEGMENT", 3.44044734343563E-02, -2.49419333469167E-02, 4.84852536089596E-03, False, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(0.06, -0.011142284242828, 2.14454006347321E-03)
Set myDimension = Part.Parameter("D1@Sketch12")
boolstatus = Part.Extension.SelectByID2("Line2", "SKETCHSEGMENT", 3.44044734343564E-02, -3.30538892391849E-02, 0.014359094338038, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByRay(6.00000000000023E-02, -2.86715682399134E-02, -1.84616927203346E-02, -1, 0, 0, 3.17018965904735E-04, 1, True, 0, 0)
Set myDisplayDim = Part.AddDimension2(0.06, -7.03968586053144E-03, -1.80887292310349E-02)
boolstatus = Part.Extension.SelectByID2("D1@Sketch12@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D2@Sketch12")
myDimension.SystemValue = 0.006
boolstatus = Part.Extension.SelectByID2("Line3", "SKETCHSEGMENT", 3.44044734343563E-02, -2.54081377085413E-02, -1.86481744649844E-04, False, 0, Nothing, 0)
Part.SelectMidpoint
boolstatus = Part.Extension.SelectByRay(6.00000000000023E-02, -2.03731306029953E-02, -2.70398529742274E-02, -1, 0, 0, 3.17018965904735E-04, 1, True, 0, 0)
Set myDisplayDim = Part.AddDimension2(0.06, -1.43124739018754E-02, -0.03599097671742)
boolstatus = Part.Extension.SelectByID2("D2@Sketch12@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D3@Sketch12")
myDimension.SystemValue = 0.025
Set myFeature = Part.FeatureManager.FeatureCut4(True, False, False, 1, 0, 0.01, 0.01, False, False, False, False, 1.74532925199433E-02, 1.74532925199433E-02, False, False, False, False, False, True, True, True, True, False, 0, 0, False, False)
